I had forgot about the stepped liners. From what I can see the step is about where the upper ring will be on the pistons I plan to use at tdc.Yes the pistons have the Wrist pin 3.5mm higher. Remember it is a hemi with stepped liners the space available above the pin and below the Step is full of rings with nowhere else to go, also the crown height is still quite high. The engines actual configuration places several constraints on what you can do. Edit See Caption Below.
