A/C was not working had it serviced and re-gassed, worked for a while then stop but started to work again, now it is not working (clutch not engaging).
Removed the engine fan, stripped it down and Ohms tested the wiring all appears OK, then check the relay, it activated when tested next checked the voltage on the relay with the ignition on, voltage to both large pins, turn ignition off voltage to only one large pin. Anyone have any idea what may be causing the problem??
