Yes, and that's my point. ANYTHING is possible.is it posssibl that the wires to the pressure switch ,have been disconected inadvertantly while fiddling with the fan wireing ,thereby giveing the impresion that the system is low on gas when in fact it isnt .PUGS sorry about the spelling my mouse has died ,christmas morning and my big fingers arnt copeing with this touch sensitive thing
The OP must establish (with empirical evidence) that things are or are not working.
For example the dye on the outside of the compressor is evidence that at some time UV dye got onto the outside of the compressor. It is not proof that the compressor is leaking...now! However you could assume that it is leaking!? BUT there is apparently contradictory evidence! So what do you do?
Logical fault finding (in the absence of test equipment) works from the easiest thing to check, to the hardest.
My recommendation is to check that the thermo fan(s) work correctly. That should be easy to establish.
