My light 15 water pump drive pulley looks like it's let go on the bearing shaft on the 807 11 engine & into the radiator.
Clearly the pulleys are out of alignment with the water pump one moving nearly 25mm.
Big coolant puddle on the garage floor after coming home from a long drive yesterday.
Perhaps the Austin 1800 type radiator with huge electric fan temperature switched on & off is repairable ~ BUT ~
Will fabricate a new radiator.
May make a bigger capacity 3 or 4 core radiator to fit in the rather small space. The one, now ruined, always kept cool about 90*C even with A/C on.
Some small work ahead, not too hard, but will ask the question 'has anyone fitted an electric water/coolant pump to handle all coolant flow on this or a similar engine with success? What type unit is suitable?
Thinking of doing away with the original water pump as such & directly driving 120A alternator from a smaller fabricated cam drive pulley.
