my drain plug key snapped in half when I tried to undo the thing :trouslap:
Gearbox ones can get very tight. I bought a chrome moly 10mm Allen key secondhand from the markets for $1, cut off a section and ground one end of that down square, rounding off the sharp corners ever so slightly.
Using a 1/2 inch drive socket on the hex end of that makes it invincible.:banana:
If you make a mistake whilst grinding, there's enough of the Allen key left to make another two !
My Peugeot mechanic once applied a largish ball peen hammer to my sister's 504 differential filler plug, which was stubborn. He said that it was "acceptable practice". He's a bit heavy-handed though (with big forearms like the skipper in Gilligans Island ), and after a few whacks there was a dull clunk and we both knew in that instant that the diff housing was stuffed...it cracked in a circle around the plug.
I have done the same thing in other situations since then, but with a lighter hammer, and not so hard, and at different angles. It usually works.
My forearms are more like Gilligan's.
