The fan on the 504 motor in my ute project does not engage when power is supplied.
As I understand it, a temperature sensor on the radiator (when the temp rises to a pre-set point) powers up the feed to a carbon brush touching a slip ring on the water pump/fan pulley.
This activates an electromagnetic clutch which then engages & makes the fan & water pump turn as one.
Now one would NOT expect that slip ring to be earthed but that is the case here; when I hook up a pilot to power & then, with the other lead, touch the slip ring, the brush or the wire feed, the light comes on.
So there is a short circuit in the clutch.
Is the pulley clutch accessible for repairs?
Are new ones available?
If not do I have to somehow pin or bolt the fan to the water pump so it turns all the time?
