I have a 504 motor in my 404 Ute project
The 504 engine pipe WILL fit (if you poke your tongue out the right way) but it is uncomfortably close to the gear change mechanism etc.
I prefer to use it as the 404 unit is a bit on the skinny side and has the "Y" much closer to the manifold.
Has anyone encountered "cooking" issues with this arrangement?
Should I consider ceramic coating to lower the temperature on the surface?
