Had a rego inspection, failed, told that there is an oil leek query top and bottom and that the bushes in the lower L & R had split. Found that there was a leak in the joint of the return exhaust from the EGR to the air intake, (fine mist). Had to clean the existing mist from the front and bottom of the engine, in doing so I had to disconect the EGR at the return air intake and remove the accelerator module, to do this I tied the vacuum lines back out of the way. Finished cleaning the engine and started to put everything back and I noticed the the 2 connections (see picture) had come off and I do not know where the connection fit, I have put red tape on one of them to make it easier for someone to tell me which one goes were. I have tried putting them on one then the other nipple, does'nt make any difference to the loss of power. I have check the vacuum on all of the connections and could not find any leak. The car starts and idles normally, checked all the hoses no splits. (had a similar problem with a split hose, loss of power)
