I have a 2009 308 Touring HDi and the remote key casing has developed a hole between the open close functions from 10 years of use. Despite this the remote continues to work. Would appreciate any ideas on a fix or replacement.
Heaps of less than 10 dollar repair options on eBay
Garage C5 X7 3008 XTE
Fix it right the first time
You should also fit a silicon cover. They are about $6 each and pick your color. We changed over our 307 key case for $5 including post to home from Ebay. I changed the door lock circuit card and blade, so that worked, but didn't see the small micro clip for the ignition. The local locksmith transferred it over for free. I met a lady a week ago, with a similar 307 and key case buttons missing but still using the manual key to open the drivers door. She said it was $300 to replace the key, so I advised she could replace the case as new from Ebay for $5. Not sure if she believed me?
Before pulling everything apart to change over, double check that they are exactly the same key cases, as there may be 2 different kinds. There was for my model.
The $2 jobbie had different mounting lugs for the circuit board, and different mechanism for the key flipper. The old one had a kind of K shape and the new one looked like a London tube logo.
In the end I butchered it and forewent the key release, it just flops now, but does not cause me any grief.
One has a battery attached to the board and the other is in the lower half of the case
