I don’t see any leaks…so you think that is the issue?Inside is a metal circular wheel which is off set and driven by cam. Could be worn, caked with old oil and no longer lubricated.
Can be removed and cleaned and re assembled. If already leaking the o ring is only available from BMW as PSA don't have as a replacement item?
Thanks. I saw a video from someone who dissected one...Hopefully that is the issue...Noise comes from the top half of the engine on the right side where the vacuum pump and fuel pump is. I also checked the chain when I removed the cover. It is tight and all plastic tensioners are in good shapeHere is what is inside the cover - an oil separator and valves.
The hydraulic chain tensioner looks like a big bolt on the rear side - do not loosen it.
The chain was tight and it had no slackSometimes it is the tensioner alone which can cause chain rattle so if it is chain related then might be worth trying a new tensioner. Its ~$90 for the part and 30 mins labour to fit.
Hi. I have no direct experience with this specific vacuum pump. But here are my comments on your image.Here is a picture of what’s inside…I can barely feel them with my fingernail those marks…
Is it on its way? Also it spins freely with no issues…
Hahaha. Thanks for that. Yeah I cleaned it and put it back on. They cost a bit. I found an original new one 300 dollars...Hi. I have no direct experience with this specific vacuum pump. But here are my comments on your image.
There are original machining marks and also some tracking marks from the rotating vane on the alloy body. As you have mentioned, there is no scoring and you can't feel anything with your fingers. If it was me, I would reassemble and refit.
But if your cash is burning a hole in your pocket, replacing it won't hurt, but will hurt your bank balance.
Thanks good info here. The cover will come with the gaskets. Fingers crossed.Look at the flats of the cams and see if both cams make the same angle, which is how they should have been when the new chain was fitted (if the tech did the job correctly). This is why some tools kits include an inclinometer to measure the angle. If they differ by more than, say 5 degrees, the chain is stretched and the tensioner is taking up the slack at the moment, but it may not yet rattle. You need a dummy tensioner tool to measure the chain stretch. The most recent chain has a hole in each roller and a 2019 repair using new factory parts should be that chain. The base of the top chain guide pad should be steel, not the earlier aluminium.
A new cover should come with the gaskets as a kit. The spark plug / coil holes of some of the copies do not quite line up to the head.
