- Joined
- Aug 2, 2000
- Messages
- 11,441
I've got a pair of lower 140 lb springs available.Assembled beam going in for the second time. Forgot to mention I set shock centres to 322mm as that's what my last si was (with slight rubbing on large bumps) I'm yet to give it clearance but will see how it goes. The 21mm arb definitely helps with the scrubbing as it's slightly less independent in the rear with the bigger arb. I'll be running 15x6.5 wheels down the track. It sits slightly higher in the front than I'd like depending on the ground I'm on but that's because it has dtd gti springs. I'll be fitting around 140lb custom springs or 30mm lower xsara springs if anyone has any?
