“205 REGISTER”??????
What about an Australasian aussiefrogs: Peugeot 205 Register ("Sticky”)?
It would be good to find out how many are left and to track them!
(It could be a base for all other Froggie models too?)
Could it be based on the existing thread “Australian 16v205 register” started by Karoshi. (Sample below).
It could be used to register ALL 205s (Standard or otherwise).
Each 205 registration sheet could be numbered as registered. (ie 1 - ?) increasing by one digit as you post
the information on the thread.
· The existing 20516v registered sheets could be cut and pasted across?
· A couple of pics could be added?
· Is there a computer guru out there willing to create some kind of standard data base that could be used?
Thoughts?........
SAMPLE:
CAR Make & No: “X”
OWNER: Aussiefrogger.
DATE: 1/12/2011
BUILD DATE: 7/'92
ORIGINAL MODEL: GTi
VIN:
OWNED SINCE: 2005
COLOUR: White
SEATS: 1 or 2
SUNROOF: No
INTERIOR: None
ROLL CAGE: Yes
ENGINE: XU10J4
VALVES: 16, custom 36.5mm/30.0mm
CAPACITY: 1998cc
INDUCTION: 48mm EFI Hardware TB's
SUPERCHARGER/TURBOCHARGER: No
INLET CAM: 16S400A
EXHAUST CAM: 16S402A
PISTONS: Wiseco flat top forged
COMPRESSION: 11.5:1
INTERCOOLER: N/A
INLET MANIFOLD: custom, made from XU9J4
EXHAUST MANIFOLD: GTi6, ceramic coated
INJECTORS: Bosch 0 280 150 803
AIRFILTER: Custom
FUEL PUMP: Standard
SUMP: Custom
ECU: Haltech Sport 1000
IGNITION: M&W Pro-14, Bosch MEC718 coils (x4)
EXHAUST: 2.25"
POWER AT WHEELS: 132kW
TORQUE MAX: ???
REV LIMIT: 8200
FUEL CONSUMPTION:
CLUTCH: 1.9L Mi16
GEAR BOX/RATIO'S:
1st 2.92
2nd 1.85
3rd 1.36
4th 1.069
5th 0.865
QUICKSHIFT: Custom, rod ends all joints
DIFF: Tran-X, 4.75:1
SUSPENSION: Front - DMS coil overs, Rear - Bilstein, 23mm torsion bars, 25mm ARB
BRAKES: Front GTi6, Rear Std
WHEELS: 15x6, 15x7
MOTORSPORT: CSCA Supersprint Series, Class Non-Marque 3A
BEST CIRCUIT TIMES:
HILLClIMB TIMES?
DRAG TIMES?
60ft?
1/4 mile?
Terminal speed?
OTHER COMMENTS:*
Dyno sheets?
Drag Stripsheets?
Thoughts?........
SAMPLE:
CAR Make & No: “X”
DATE: 1/12/2011
BUILD DATE: 7/'92
ORIGINAL MODEL: GTi
VIN:
OWNED SINCE: 2005
COLOUR: White
SEATS: 1 or 2
SUNROOF: No
INTERIOR: None
ROLL CAGE: Yes
ENGINE: XU10J4
CAPACITY: 1998cc
INLET CAM: 16S400A
COMPRESSION: 11.5:1
INTERCOOLER: N/A
AIRFILTER: Custom
FUEL PUMP: Standard
SUMP: Custom
EXHAUST: 2.25"
TORQUE MAX: ???
REV LIMIT: 8200
FUEL CONSUMPTION:
CLUTCH: 1.9L Mi16
GEAR BOX/RATIO'S:
1st 2.92
2nd 1.85
3rd 1.36
4th 1.069
5th 0.865
WHEELS: 15x6, 15x7
BEST CIRCUIT TIMES:
HILLClIMB TIMES?
DRAG TIMES?
60ft?
1/4 mile?
Terminal speed?
OTHER COMMENTS:*
Dyno sheets?
Drag Stripsheets?
