I want to do a 205 gti mi16 swap.
My mechanic who I am close friends with has agreed to help me but he has no idea about how to do the swap.
I found an Mi16 long block complete motor for sale, 220,000 km it has no hoses and no ecu. The wiring loom is apparently crappy but will send pics when i get it through.
While i attempt to hold myself off from buying this to put into my 205 GTI I have some questions about the conversion.
I can find a few ECUs on ebay, one example is:
Peugeot ECU Control Module Unit 405 MI16 #: 0261200161 BOSCH $130 USD including shipping
What is the difference with the ECU models and do all of them work, any issues to look out for, do some work better than others.
Ideally I wait until I find a complete engine with ECU and loom but would this suffice if the loom is of satisfactory standard.
Does anyone know the rough cost of redoing the rings, crank bearings and head gasket for failsafe on an mi16. Any other seals etc common to need doing.
Now for what i know and what I want to know.
What i know:
- I will need to make a block to angle the exhaust down to clear the bulkhead, currently sorting this.
- I will need to grind the radiator shroud to clear the inlet manifold.
What i want to know:
- Are the engine, ecu and loom the only required things for the swap, that is.
Given I have the engine prepared with radiator shroud ground and exhaust angling block ready, ecu, wiring loom ready, is this a job that can be done over a weekend with myself (tinkerer, mainly motorbikes) and a skilled mechanic working together.
Also, if anyone who lives in Brisbane or the Gold Coast has done the swap before let me know if you can help for $.
What i know:
- All the cooling system of the original 1.9 8v plugs straight in.
- All the other stuff fit straight in?
- Does anyone have a coolant pipe diagram?
- What modifications do i need to make to the 405 Mi16 loom (what cables need to be spliced into it)
- Will the exhaust manifold bolt onto the original 205 exhaust once angled correctly.
