Hi all...well i noticed a frayed clutch cable so i ordered a new clutch cable from EAI in box hill and had my mechanic install it.
all seemed well and i had a normal feel when i depressed the clutch...no excessive force needed to depress the clutch
after some kms went by i noticed the clutch pedal would sometimes stick near floor and id get my foot under it to get it back up...shortly after the cable broke the plastic bit that stops it going through the firewall....
so i send photos to AEI and they say no manufacturing fault and that its the result of excessive force
quote ..
He has said the failure is not due to a manufacturing fault.
It appears that the failure has occurred due to excessive force on the outer sheath leading to the plastic mounting point to snap, the excessive force could have occurred due to a stiff clutch operation.
so i sought further clarification and got this..quote ...
We can only see the damage to the cable.
We have previously not received a claim on a clutch cable with this problem.
The cable has been in the vehicle without an issue until now, something has now caused excessive force to brake the mounting on the outer cable. This would have been caused by the clutch operation, that is where you need to look for a problem.
so...is this incorrect installation? or could it be the clutch fork is somehow stiff or stuck??
appreciate your input
quote ..
