I don't remember ever seeing a rubber pad between the top of the spring and the cross member. It's easy to see why the Dauphine and then R8 models are so much smoother and quieter than the 4CV.I will have a gaiter on the gear linkage, but it will have to wait until I place an order with one of the French suppliers. My current question is this: Is there a rubber pad between the rear spring and the top of the crossmember? There are two rubber pieces on each side (at the top) for the rod that limits axle travel. There was no piece of rubber between the spring and crossmember, not even little left over bits. My ETAI 4cv book shows the following, but I don't see a rubber isolator in the catalog of any suppliers. I have a couple of left over Toyota rear strut mounts that I could make into spring isolators if I have to.
I think we have something in common. I too love shiny paint. Paint everything, I reckon.I know the shiny finish is a bit over the top, but it is durable and easy to clean. Besides, all that paint and clear coat will magically repair any wear inside the gearbox!
Yes there is. It gets dirty, then stained and then I am so disappointed all the work was for nothing.There's nothing wrong with shiny bits under a car.
You use the wrong paint. Rattle cans are not quality. Get some real paint ......Yes there is. It gets dirty, then stained and then I am so disappointed all the work was for nothing.
You know a stitched-on leather boot hadn't occurred to me. Lateral thinking. Kudu or springbok?Hi Stan,
Axle boots will be easy, I have been an Off-Road racer in a past life..... and with the fancy suspensions it was always difficult to get the rubber boots to last. So we made them out of leather, much more durable than a rubber boot, and once they have grease inside they are fully water proof. I started using them on my Dauphine when an apprentice.
Ray
Mr Shoji cleans it again I think. I look under mine occasionally and it always looks about the same so I don't get upset. I'm really most concerned to see no drips. My R8 doesn't drip but there is a hint of oil at the trunnion housing (those threads...), just enough for it always to be filthy but no worse. So I close my eyes to it. She's a working girl after all.Yes there is. It gets dirty, then stained and then I am so disappointed all the work was for nothing.
I have the earlier, dry element filter alone. Not sure about USA, but our later cars had dual filters, with a dry element piping air to an oil bath filter. Both my early type and the later dry filter canister can accomodate standard paper filters, the original filters being pretty ordinary at best for fine dust. The later ones are almost the right size for a SAAB 900 filter and I found a paper element for my earlier one in the end. I guess you just have the single unit you've shown in the photo? You might find a paper element that fits with some foam padding to seal it.I use rattle cans sometimes, but usually put clear coat over the paint. I don't think the original 4cv air filter is very good. I would like to put a modern filter inside the original housing. Does anyone know how to remove the cone shaped wire filter from the top of the original assembly? Also pictured is my rock tumbler. I don't use it to tumble rocks, just parts and dirty golf balls. All hardware and most anything else that will fit goes through the rock tumbler and comes out clean and shiny. I use a jumble of small hardware as my tumbling media for steel parts. The barrel is filled with water and dish soap. I have scraps of shoe sole leather for aluminum and brass parts. I always wanted a big tumbler, and starting the 4cv project gave me a reason to go ahead and get it built.
View attachment 128146View attachment 128147
