For $140, I'm sold.
That aught to apeall to the tight asses or cash strapped among you.
Jo
Wash your mouth out with soap Proffi, that's 'tight-arses'!
cheers! peter (the culturally pure)
For $140, I'm sold.
Jo
For $140, I'm sold.
I just returned from a spirited drive around the race track, and whilst I was too cautious in this atrocious weather to really let loose with brand new rubber and unknow front/rear ballance, I can say from what risks i did take these tyres are not bad.
I'll reserve judgement for how good they are until I have put a few Km on them, but for $140...jeez thats possibly the cheapest tyre I have ever bought.
Jo
I did say they were probably the best bang for your buck They are certainly not the best tyres I've had performance wise, but they are certainly the best value! and the tyres I've had that *are* better have long since gone the way of the dodo. I think you will like them in the dry I'm not sure about them in the wet. I've been a lot more conservative after a lose on Mt Victoria about 10 years ago, hitting some oil on a wet road.
Tony.
I assume you are talking about the footprint?
Tony.
Not weird, totaly normal.That is interesting though that they spec them as 201mm on the link you provided but the 205's range from 206mm to 217mm depending on diameter and profile... weird...
One thing is interesting about the tyre
I couldn't help notice its a big tyre for 195.....:wink2:
Maybe i need to get a new 'tyre sized' rule, but no mater how I tried i could not get it to measure 195.
I'm running 6.5 wide rims (+0.5 over spec) so my measure gave me 210mm (at night).
A quick check on the net found a tyre size chart that is not full of BS, A surth erfrican site.
http://www.bridgestone.co.za/products/passenger_tyres/potenza/potenza_adrenalin_re002
Our AU website says for a 195/55/15 tyre the width is....195.....Ah der, I can read a sidewall too.
I hate the way companies who have the details, dumb down their websites.
If someone wants more detailed info than is on the sidewall (lies lies lies) the australian publicity dept just dont provide it anymore.
Jo
The actual section width is allowed to vary by +/- 4%.
Since the nominal width of a 195/55 R15 tyre measured on a 6.0 J rim is 201 mm (don't ask, I've no idea why), a variance of 4% means it can be anywhere from 194 mm to 209 mm (again, as measured on a 6.0 J rim).
A general rule is to add or subtract 5 mm for every half inch change from the measuring rim width. Thus, if the table on the Bridgestone website is actually accurate (is it really 201 mm, or did they just quote the design manual?), the width of a RE002 tyre in a 195/55 R15 size and measured on a 6.5 J rim should be approx. 206 mm.
As always, YMMV. :crazy:
just a quick question we have an s16 on standard 15" rims and my son would love to put some larger rims on it whats the thoughts on this because im not sure it will be possible i can hardly get my hand in there as it is , im a great beliver in that peugeot spend millions on handling and setting up the cars for someone to go to the local "Kmart bob tyre repairs" shop and totally stuff handling ride comfort etc etc. however he has some cash and is very keen, for some 17 spoked jobbys on rubber band tread. your comments are appreciated
steve
Beauty is in the eye of the beholder.
I had a mate who did what you son wants to do, but it was to a honda integra.
His car slammed over bumps, would not stop or turn well on anything but mirror smooth roads and was a pig to drive.
The weight of his 17inch rims and tyres was huge, so all areas of performance, especial acceleration suffered.
Then there was the increased cost of rubber band tyres....
Jo
Following my request for suggestions for tyres for a 406 SV a few weeks ago, I am still checking out the possibilities.
The Bridgie ER 700 does come in my size (205/60 15), but the RE 002 does not. Reports are generally favourable.
I went to my local Michelin man who was not surprised by the lack of longevity in the C-drives. I did not realise how soft the compound was when I got them.
The Michie discussion swung from Premacy to XM2. This tyre would be suitable for my needs, the sticking point (pun intended) is the size/price combination.
195/60 and 205/65 are common sizes, and go for about $130. Ask for a 205/60 and the price I was quoted was $212. Plenty of tyre threads are littered with explanations and warnings of higher process for uncommon sizes.
So, the question is, for a difference of well over $300 per set, can the size fitted to a 406 SV be compromised to such an extent, either a poofteenth narrower (195 v 205), or a few % (60 v 65) bigger on the rolling circumference?
Look at load rating on the door placard...it may be a factor in deciding which tyre to choose.
Jo
......snip.....
So that was $220 a corner, plus $125 for 4wheel alignment, from Chateswood Tyre and auto, as recommended by PQ. Tell you in 5000k how that went!
.....snip...
steve
Chris,
Did you watch them do the 4 wheel alignment ? What do they adjust on the rear of the 406 ?
For $140, I'm sold.
Jo
