I'm going up for the Saturday afternoon and evening only so I'll see you guys there.
If drilling the disk is a no no how are you doing the front? 4 holes?
On the rear are the r16 disks normally clearanced for the wheel studs, or do they not interfere? I've seen big brake kits with clearanced disks.
Sent from my Nexus 6P using aussiefrogs mobile app
Kevin, I have just come across this thread. Back in post 65 you have shown some parts you have electro plated, there is a serious problem you can have if you plate medium or high carbon steel, it is called hydrogen embrittlement. As the name implies the plated parts become brittle which can be dangerous for important safety parts like springs or retaining spring clips. Could I suggest putting on a set of safety specs and trying to flex those spring clips? They might be OK but the problem is the inconsistency of process.
Regards, Phillip.
