Does anyone know if Kel's 330 gearbox would be the later type (R10 1300) with the beefier input shaft and tube-type guide for the throwout bearing? This would be needed along with a mk1 R5/Lecar flywheel if he wants to fit a 1.4 motor.
Unless you add a turboYou have a 3.9 R16 is 3.77 and that's it. going to 5 speed there is 3.9, 3.77 and 3.3 which is a big step and needs torque to work. Always remember these old cars cannot be made to behave like modern cars which have much more Diesel like torque curves nowadays
Ray what is that nose cone off of? It's not a 330 or 353 piece.Also to what "dauphproto" has said above, the chassis need cutting and welding, in the backbone tube to rear frame assemblies, for the Big5Speed nose clearance. The areas where red lines are drawn.
Ray
View attachment 237654View attachment 237655
If I remember right Steven used a 395 with a few modifications. Once I got the gates right it was a nice pattern to shift. It worked well with the shift shafts I think he took from the 365 or the 385; It was a hybrid box. 385 C/W&P, 365 close ratio gears, and a few things taken from the 3 boxes, all in a 330. Very nice with the 1647 motor.Ray what is that nose cone off of? It's not a 330 or 353 piece.
