Hi All,
As the title says I’m wanting to fix an oil leak without pulling the engine out. I replaced the rear main seal last time I had the engine out and did the clutch. I assumed it was the source of the leak but it’s leaking in the same area so it may be the L shaped seals in the main bearing cap. Obviously I’d need to be careful not to disturb things too much and use feeler gauges to hold the seal in place when refitting it, but in principle would it be possible??
Otherwise I’ll pull out the engine again and do it all properly again.
