WTD R8/R10 Steering Boss Kit
Fireblade
Active member
Hi,
Anybody with a steering boss kit for early(ish) Regie's surplus to their needs? Looking for a 6 x 74mm PCD (Nardi I think). I believe any Renault model up to a 1982 Fuego will do.
There are 2 spline types on an R8. Early bigger diameter up to 68 then smaller finer from 68 on. This would be European spec.
To put it another way an 11 turbo wheel will fit a later R8, but not an early one
  • Like
Reactions: COL
It's actually for a '67 Caravelle, so early pre '68 - definitely bigger diameter type
I have an OBA boss kit for the larger fine spline. New in box, with an adapter ring to go from the Euro 7 bolt to a 6 bolt which should suit a Nardi.
Message me if you are interested
Matt
I've also got a couple of others, one large fine spline, one smaller coarse spline, both with 6x78mm mounting
