Hi
Looking for a 205 GTI beam tube in good working order.
I'd cut and shut a 306 beam if you can't find one.
Is the tube hard steel or some sort of near-bearing quality kind of steel?
How much wider is a 306 tube compared to a 205 tube?There are lots of good 306 beams around but not many 205 beams. Eventually you'll need to do something different when 205 supply dries up. Shortening a 306 beam is one example. Repair welding and re-machining a 205 beam is another. 306 beams are otherwise identical.
