Wiring genius
Sejsonic
Hi Froggers
Just in a bit of a pickle, needing some help with wiring on my 205, trying to get a MI16 with 45’s and ignition system to work and getting no where fast.
I’ve done something wrong and can’t find it, is there anybody who can come and have a look in Melbourne area?
Tell us how the ignition works. What parts?
Hi Peter, I’m running a nordiz ignition control unit that runs a wasted spark coil, runs from the original crank sensor and has tps on 45’s, unit works just having issues with car wiring and making it fire it up, would appreciate if someone who has a lot more experience than me could help.
Will need to get you a schematic for nordiz, but coil is for a Opel, or ford, if you look on YouTube and search for nodiz lots of Peugeot in uk use this system
A bit of background might help us make some sensible suggestions and seeing that you don't get any answers from Melvegas I take it people are otherwise occupied.
So here goes nothing.
How do we know this is an ignition issue?
Assuming you have a compelling answer above,
Did the car ever run with this system, or is this a new install?
What happens when you turn the key?
Did you do any test to see if there is spark when you crank?
