Window tilting
Vlad
Melbourne
Hi froggers
Sometime ago my driver's side window regulator green clip broke and dropped the window. Then the cables got stuck inside the main pulley part so I had to get a cable and pulley repair kit which worked a treat. So the original issue is fixed.
However now my window tilts forward when going up, exposing the part of the glass that normally sits deep inside the b pillar guide. And I can also see a small hole in the corner of the glass.
What am I missing?
As mentioned in your parts thread, there will be a plastic runner at the top, rear corner of the glass and it's either broken or fallen out when you repaired the window regulator.
What am I missing?
