Am after fuel inlet manifolds to suit 45 DCOE side draught Webers and R16 engine. Checked the usual sites like Mecaparts, GBS Alpine and Simons Auto but none have them listed. Does anyone have them for sale or know where I can get them?
Just drop the turbo Fuego engine in.Possibly - just seeing what I can get to do it.
MP0933 ? currently listed Mecaparts under R12 G and A110 for 399 euroAm after fuel inlet manifolds to suit 45 DCOE side draught Webers and R16 engine. Checked the usual sites like Mecaparts, GBS Alpine and Simons Auto but none have them listed. Does anyone have them for sale or know where I can get them?
Hi TimJust drop the turbo Fuego engine in.
But how good would that look when you open the engine lid on the A110! Might send it quickly as well. I challenge you to fit it Barry.Hi Tim
Here is a photo of my Fuego Turbo engine. Might be too big for the A110 so looking at just having side draught Webers and normal exhaust. Will advertise the complete package for sale and if not sold will consider using the engine in the A110 and sell off the remaining bits like the R17 fuel injection system, the turbo, intercooler and oil cooler etc. The engine was built by Justin Eckersley who part owned Alpine Motors in Canberra and was in my Fuego Turbo which I have sold. It ran beautifully up and down the Monaro Highway as a test run and I removed it after that and replaced it with the original A5L motor which was still good. It only has about 100kms on the new motor.
It'd fit in my car!Hi Tim
Used an old MOTEC computer. It needed a Commodore 64 laptop to program it. As we shot along the Monaro Highway, my companion was changing the settings to maximise torque and boy did it go. Trouble was it keep the fuel injectors on and fuel was diluting the oil. We could not figure out the problem so put in a Microtech system (ofter used on rotary engines) but could not get that to work either plus had trouble connecting the power steering pump in its proper position. So took the motor out and put the A5L motor back in which uses a pressurised carbie and picks up the signal off the flywheel. Yes it is a twin coil on the back of the head.Wow. What engine management do you run on that turbo motor? I think I see a crank trigger on the front, and is that wasted spark coils on the back of the head?
Awesome looking engine Barry, I reckon it would go close to fitting as the engine bay of the A110 is fairly wide.Hi Tim
You just need a turbo and a modern engine managementIt'd fit in my car!
I'll start with the modern management. Then 1800cc, then a turbo....You just need a turbo and a modern engine management
They were Bosch injectors. Not sure if they were the problem. With hindsight, we did not use the hand controller that came with the Motec and perhaps that might have fixed the issue. I was just so disappointed at the time when it was running so well particularly on full boost. I think it would be a real handful in an A110. It might fit and will certainly fit in an A310 which has much more engine room.Thanks for the explanation of management. What injectors did you run? Wonder if that could have affected continuously fueling. I’m sure there will be a fair bit of interest when you put the motor setup up for sale.
