Don't do it! If the quality is anything like that of the chinese lawn mower my sister bought, you'd be lucky to even get it fitted without something breaking off!
Alec
I seized a passing opportunity. Used V-blocks in a press, with pump sunny side up pushed the pulley down onto the casting first, then pushed the shaft through the pulley, then the bearing shell out of the casting with impeller still attached. Casting will clean up nicely.
The OEM shaft/bearing assembly is made by Koyo. I don't yet have a part number for them. It's rooted from water ingress. FAG bearing is apparently W2431-SS (availability poor) with the caveat of not having yet removed the impeller to confirm shaft diameter - just used sliding calipers. Getting these numbers right when you are somewhat dyslexic can be a real mongrel.
There is (was?) a mechanical seal at the impeller back; its rubber bellows failed and wasted away. The rotating seal face (not the static part, the dynamic section) is also no longer bonded to its backing.
Overall, I want to make two points. First I forgot to post this thread in the Pond (sorry David!) but secondly it gives much hope to the idea of salvaging an expensive part from failed units. "We" only need a spec and P/N for the carbon face mechanical seal and it's close to sorted.
Good work there Addo. Just need to get those bearings and seals off that shaft and hunt down the numbers on them.
Another way is to find some off the shelf bearings and seals that will fit without any machining to the housing.
These are about the best examples I can find without dismantling.
Automotive Pump Seals,automotive water pump seal Manufacturers Factory in china
Just thinking aloud...
I wonder if there is a pump/seal kit for another vehicle/marque that can provided a donor seal. Finding the vehicle will be the issue .
The mob in the link mayl want to sell a few hundred/thousand.
You may find a donor pump with a suitable seal at a price that is practical to sacrifice it.
