Have just had my wiring loom changed by Citroen dealer to a genuine one from Citroen France.
Citroen Australia have been supplying a bypass system as genuine, also (the towbar is not genuine but will do the job) and claiming its because of ADR's well this is a fallacy as these cars come under the EEC regulations not ADR's and are accepted here by the ADR regulators.
If you fit a non genuine wiring loom you run the risk of an accident if your caravan starts to weave from side to side. The car computer will not know that it has an extra load on behind it.
The genuine loom when fitted and has lexia connected will be programmed into the system and when you hook up the load on behind it lets computer know and it will activate what is generally known as TSP. If the load on behind starts to weave from side to side the ESP takes the appropriate action to bring it under control before an accident occurs. Fitting a genuine tow bar will eliminate having to cut your rear bumper. It appears to me that it has all come down to price so the choice is yours fit non genuine and take your life into your hands or have genuine fitted and be safe. Interesting that Citroen Australia don't mention the fact that fitting a non genuine accessory will void your warranty if it caused a problem and possibly your insurance company would also void your claim if the tow bar and wiring was the cause of an accident. I also feel that importers are using a loop hole in ADR regulations, I intend taking this matter up with them. So if your thinking of getting a genuine towbar and wiring check it out and make sure it is genuine, ask to see it before installation and check the part numbers. If you wish to do it yourself we have an importer in Gold Coast who imports genuine parts and wiring looms. but must be 13 pin not 7 pin. why because 13 pin has a micro switch that disables the reverse sensors and lets the computer know a load has been connected.
Hope this information prevents someone from having a accident.
