My grinder is braked. These things spin too quickly for comfort without braking.I'm never in hurry at home, so I just wait until it stops spinning.
loose connections create heat and then eventually the joint will not conduct electricity anymore as the metal gets burnt away. I would go round and check all the other connections on the welder, both external and internal to make sure they are tight. You will then get another 35 years of good welds.I've been having some trouble with my fixed amp CIG welder for a couple of years now.
The thing is 35 years old, and sometimes it will lay down a nice weld, and other times it is as frustrating as f#ck.
I just put it down to old age (the welder, not me).
Well I was packing it up this morning and the earth clamp fell off the lead.
The copper was all blackened, corroded and crumbling, and I had to shorten the lead by about 3 inches before I hit nice bright copper again.
Hopefully my welding will be more consistent going forward.
Sometimes it's the simplest of things.
The leads themselves are only 15 years old, they don't make sh#t like they used to.loose connections create heat and then eventually the joint will not conduct electricity anymore as the metal gets burnt away. I would go round and check all the other connections on the welder, both external and internal to make sure they are tight. You will then get another 35 years of good welds.
man you need to try youreself a modern mig welder with gas ..... and a self dimming helmet. it'll be a revelation!The leads themselves are only 15 years old, they don't make sh#t like they used to.
I have a self dimming helmet, it came with the inverter welder (that I've used once).man you need to try youreself a modern mig welder with gas ..... and a self dimming helmet. it'll be a revelation!
So it sounds like it's normal, I just hadn't struck it before. Probably because I deliberately centred the blade over the tube as I didn't want to cut right through, just the top surface at each end. I think with the work clamp back in it's normal position, the blade would always hit a corner first, then it cuts through like a piece of cheese.patience mate.... it's got lots more work to do on the big flat side, I've cut 3" wide 1/2" thick MS here on the wide side, just needs a little patience. As soon as it bites through into the hollow bit it'll go like tram
Bob
That is a huge surface area to try and cut at once. flip it 90degrees so it strands verticle and it'll cut much better. I have a little bandsaw I use for these sort of cuts now. its much slower, but so much better in every way than the abrasive cuttoff wheels.Similar to grinding wheels, but with the fibre mesh built in, they seem to be more resistant to flying apart, that is cut-off wheel blades. Fortunately, because the first pic below shows what I found when using the original disc on my Ryobi cut-off wheel yesterday. Weird also, because I thought it was the cause of a problem, then found it probably made no difference. I had already cut a 1 metre length off a length of 50x25x3mm galv RHS without noticing anything. Then I set the machine to make a fairly horizontal cut across the 50mm side, as I didn't want to cut right through. Anyway, after the cut was started it got harder to push down, I actually thought the stop must have moved, preventing any further movement, but it was ok. It felt like it was glazed up, just getting very hot but not cutting even with high pressure downwards. So I look at the blade and notice the piece broken out - I don't know when that had occurred, but I had recently lent the machine to neighbour, maybe then. I thought, wow, that could have flown to bits, but it didn't.
So I bought a new wheel, Flexovit for good quality, and strangely, had the same effect with the cuts as deep as you can see in the close up. I reversed the tube and cut from each side to nearly achieve what I wanted. I then decided it just did not like the flat surface, so I gave up on that, and to cut off the smaller pieces fully through, I turned the tube on its side so it started cutting on a corner - straight through. Interesting though. Anyone else had the same experience, the wheel cuts through the thin sides easily, but doesn't like starting on the flat surface.
Looked like a bit of hand sawing to be done, but the Makita recip hacksaw did a good job quite quickly on the same cuts.
View attachment 241711View attachment 241712View attachment 241713View attachment 241714View attachment 241715
I bought one of those Ryobi cut-off machines many years ago. I would still have it somewhere, probably in the junk shed behind my main shed?Similar to grinding wheels, but with the fibre mesh built in, they seem to be more resistant to flying apart, that is cut-off wheel blades. Fortunately, because the first pic below shows what I found when using the original disc on my Ryobi cut-off wheel yesterday. Weird also, because I thought it was the cause of a problem, then found it probably made no difference. I had already cut a 1 metre length off a length of 50x25x3mm galv RHS without noticing anything. Then I set the machine to make a fairly horizontal cut across the 50mm side, as I didn't want to cut right through. Anyway, after the cut was started it got harder to push down, I actually thought the stop must have moved, preventing any further movement, but it was ok. It felt like it was glazed up, just getting very hot but not cutting even with high pressure downwards. So I look at the blade and notice the piece broken out - I don't know when that had occurred, but I had recently lent the machine to neighbour, maybe then. I thought, wow, that could have flown to bits, but it didn't.
I have a cheapo (not ryobi branded) one too... Its never made a straight usable cut no matter how hard I've tried......I bought one of those Ryobi cut-off machines many years ago. I would still have it somewhere, probably in the junk shed behind my main shed?
I don't know if they ended up up improving them, but the one I had/have would actually twist when I started applying pressure to whatever I was cutting.
I could never get a straiģht cut out of it in the up and down direction, so it went into purgatory in the back shed.
Thanks for the heads up, but I am all out of 84mm cannons at presentThe things you see on Marketplace.
Anyone chasing barrel cleaning brushes for a Centurion tank?
Seller doesn't state the barrel diameter, but given the 1955 date, I'm guessing 84mm?
Large quantity available, $50 each, get in quick.
View attachment 241742View attachment 241741
Yes, and my Centurion is an early model with the 3" gun.Thanks for the heads up, but I am all out of 84mm cannons at present
