wow ... no ... I hadn't google it yet. I just saw the advert and sent him a message "I'll take it, just let me know a location and time". It would be worth that asking price in scrap metal. Its bloody heavy and all copper. I'll google it in a minute and see if I can find a manual.Did you spot this?
Used sip - italy Supermig 225 DP Mig Welding Machine Mig Welder in BAYSWATER NORTH, VIC <883730>
Buy Used sip - italy Supermig 225 DP Mig Welding Machine SIP Supermig 225 DP Mig Welding Machine for sale by Newmac Equipment Pty Ltd - BAYSWATER NORTH. <883730>www.machines4u.com.au
I must admit I'm quite concerned about how he insisted it was onlly good for really thick metal. So I went through the stuff with it. A new bag of 1.2mm tips (that I later found didn't fit the welder ) and 3 brand new rolls of 5kg 1.2mm gasless wire ....
XCELARC 1.2mm 4.5kg Gasless MIG Wire XA-E71T11-12-45
<p>Xcel-Arc E71T-11 is a general-purpose self-shielded flux-cored wire designed for all position, single-pass and limited multiple-pass lap, fillet, and butt welds on mild or galvanized steed of less than ¾” thickness. (Do not use on steel plates thicker than ¾”). Xcel-Arc E71T-11 is easy to use...
www.totaltools.com.au
The wire is worth what I paid for the welder Damn, those 3 rolls of crappy gasless wire are worth $240.00. anyway, I flipped the wire feed roller over, and it seems drive the 0.8mm wire I already have fine. However .... Why is my roll of 0.8mm wire that has always been kept in my shed ..... rusty as buggery.
So I fed the rusty, 0.8mm wire into the welder, flipped the polarity over to gas. and hilariously found the tips for my little 25year old ryobi welder fit it perfectly.
so I searched the shed for a challenge..... Hmm... a rusted off ID19 downpip. Its gone black and opened a hole with a wire brushed it.
So rusty 0.8mm wire (not 0.6mm wire like the little ryobi is running) .... and look at that. bloody incredible. Yes, you can onlyl do "tacks" at thihs thichkess with any welder.
even toward the end where its microns thick ... I could have booger welded it up and built up the metal if I'd tried.
This thing is bloody incredible. I couldn't be happier with it.
