I've often thought can these hubs/drums be taken to a machine shop and professionally fitted with new studs in a pattern to suit suitable wheels of 4 stud. Or is this not going to pass roadworthy?Hi
Are there any Kits available to convert three to four stud bolt pattern for my 16 TS. Or can I use later model Renaults that have four studs . Appreciate any advice.
Thanks.
Why?Hi
Thanks.
JohnW, with a 4 stud pattern there is a vastly superior range of wheel diameters, offsets, quality and styles available, both new and used. In most cases, far cheaper than 3 stud to suit old Renaults.Why?
Pretty sure QLD regs don't permit redrilling of hubs and drums. Don't know about other states though.I've often thought can these hubs/drums be taken to a machine shop and professionally fitted with new studs in a pattern to suit suitable wheels of 4 stud. Or is this not going to pass roadworthy?
Thanks for your reply. I just wanted to have the option of choosing different wheel designs etc.No kit or easy answer. It is probably possible to use Drums and front hub spouts from different cars, but may require finding bearings to suit the different diameters encountered. Did this once to convert a Vauxhall /Peugeot, hub/Driveshaft combo or you make alloy spacers that attach 3 stud which are re-drilled for your 4 stud pattern. None of these are easy options, it depends on your patience/ingenuity.
Was there a wheel size you had in mind ? Or were you just wondering if there was an easy option, which there isn't. I have been working on bits of an A110 which has been converted to 4 stud, but this is because it is a stage rally car and the 3-4 sets of wheels required make 4 stud and all the engineering viable. also it may damage a wheel at any time meaning easy replacements are cheap. I guess you will not be swapping wheels on a 16 all the time.
Custom 4 stud are very reasonable, not 3 stud. Hence the reason to change the hub to 4 stud.Surely custom wheels are cheaper...?
