The varnish that detailers use on engines
Beano
Brisbane
I have seen car engines (usually in secondhand car yards) that look pristine because they appear to have some kind of varnish applied to them. Like this :
But when I smell it I cannot smell anything. Can anyone tell me what kind of varnish it is ? I am guessing acrylic clear top coat, but how well do you need to prepare the surface ? Because I imagine that unless it is spotlessly clean and dry to begin with, the final look will be awful...
The longevity is what I am worried about. A test would have to be for a long time.
Perhaps my question should be : how long does it take till the acrylic starts to flake, peel, and look like crap ? :blackeye:
I didn't know high-temp clear existed....just engine enamel. I'll go down to Repco and Supercheap....
I was at a paint merchants in Sydney recently picking up some "weld-through" primer for one of my projects, also went home with an aerosol of 'clear coat' {though not high temperature}. Got this because my Merc 124 has sun damage to one rear fender. I have to say that {after rubbing down & 'liquid cutting'} it initially went on & made the thing look 100% better - but then I got too impatient & sprayed a subsequent coat too soon {at least too soon for the sub-arcticness of Katoomba, was going by what it said on the tin}. Now I've got dribbles {& the car's not looking so good either}, so will have to rub down & reapply - maybe in a couple of seasons :-/
I'm suspecting you may have to get onto an auto-paint specialist store, but try Repco / SCA - surprising what they do stock sometimes.
Happy fixing,
Rob
Tyre shine may have similar effect ,i have used it in the black plastic skirts /bumpers on my vw transporter to good effect, but its short term ,pugs
I want to retract my post on tyre shine ,read the instructions ,i just did ,its seriously gnarly stuff ,wear a respirator and only use as directed , i will be in future, pugs
Have seen tyre shine used on the interior of a dunger and it worked wonders on the door trims and dashboard, as least as good as Armourall. Not that I would use either on my cars however.
