Several Issues - Peugeot 308 Allure Turbo 5d Hatchback
daveturn79
New member
Hi all
After some friendly advice on fixing vs not fixing and getting rid of car
Any suggestions ??
Several issues and faults found including these below, car has issues with compression on engine also
P0016
P0172
P2600
P2279
P0087
12A7H/4775
U1208
You haven’t said what engine or year but let’s assume from the faults it’s a 1.6 turbo it probably needs a timing chain, electrical thermostat and a high pressure fuel pump and the knocking that has been occurring has cracked a piston my diagnosis burn it not worth fixing problems have been let go to long
It is quite a code collection, including the cam shaft sensor, the exhaust oxygen sensor, coolant pump control, air leak, injection rail pressure, and engine computer signal. Were the codes cleared and re-read to remove old history?
Rest omitted. See dmcc above.
Thanks for tips.
Codes picked up in recent complete scan.
Figuring would cost $3-4K min to fix whether thats worth it not so sure.
