ok guys and gals....I ve had the s16 for less than a week and i m already thinking about performance mods on this car....i ve read the puma racing site (which i reffered to often in regards to my 205gti...What i d like to know is what types of mods have u guys performed on your 16 valve motors with reasonable succes....
i ve fitted a new sony head unit, and the brushed aluminum gear knob (which goes well with the sony)....by the way the knob came of easily once i figured the mechanics of it.....u can not twist those things....it was simply a matter of lifting up (pulling up) and the thing came of quite easily....anyway i ve also fitted a mushroom style filter 2 it and while looking at the throtle body i started to wonder if there was a BIGGER unit available...either of a pug or another machine...
I m aware that there are bigger throtles available aftermarket but at about $500 they r not that cheap.....anybody aware of alternatives...
Which also brings me to the topic of the various
pug 16valve engine power outputs....DID the earlier mi16 put out more power? if so---WHY...have these been detuned in any way??
Somebody (i think Peter) mentined advancing the timing on these things by 3 degrees.....further commentary on this would be appriciated....
Also, whats the situation on the coil packs with these cars.....i ve read they fail regularly....any way of reverting to older system or was the mi16 running same set up....i d like to see the ignition side become more reliable any ideas...?
thanks
cheers
dino
thanks
cheers
dino
