PeterT originally recommended it to me.
The 306 has 2 different sized end plates for the arb a 24.xmm and a 25.xmm end - remove both end plates and measure the bar against the 205 arb and mark where the 205 bar ENDs on 25.xmm end of the 306 arb.
Double check you have the correct end, then cut the bar. CleAn the now cut arb and clean the 25.xmm end plate. Insert the cut end of the bar into the end plate and slide it all the way to the end. Now weld the end plate to the bar.
It's critical that you align the two ends with the end caps on before you weld to make sure end plates will mount properly - as the cut bar end rotates in the end plate it's pretty easy to do if you have a nice flat surface ( just put the other endplate on before welding).
The downside is you always have to remove from the welded side, but you now have a cheap 24mm arb for the 205.
Same thing can be done for the 309 and 405(I think).
The 306 s16 and gti-6 both run the 24mm arb. Some of the citroens also would no doubt.
Its not too large when you consider the 106 gti and saxo also run a 24mm arb factory. I used it on my 205 with factory torsion bars and it was awesome...
There is a photo of the welded end in my thread - search broom broom
