Hi All,
I have posted before about converting the rear drums to discs on my series 1 205 GTi.(subframe from 309).
I also understand that most of the braking force is applied to the front wheels as physics would imply. These things I know.
What I would like to know is the actual difference in the two set ups from the s1 to the s2 rears. I have seen written on a UK site that its simply the locating pin being longer on the s2 than the s1 when fitting rear discs, but this part is not available as a genuine Peugeot article.I have found a site selling this exact bit, more than likely for a conversion of this type, but 30 pound before freight seems a bit high for 2 pins, and surely someone in Oz would be able to whizz this up on a lathe ?
306 discs should fit up front, but would the left over fronts then be able to be transferred to the rear (bearings should be the same?)utilising the caliper as well.
If not, would the rear disc assembly of a series 2 be able to be bought new or second hand and be slotted onto a series 1 rear suspension arm? Where would the caliper mount?
I know this is a lot of trouble to go to, but after my little effort on the weekend, I want to upgrade the brakes regardless.
1 last thing, are the series 2 master cylinders larger in bore diameter than the series 1, and will a 405 master cylinder fit?
Chipper
Chipper
