Has anyone mucked about with the climate control fitted to later R25s?
My A/C bloke says mine is cycling the compressor at too high a temp ie. around 10 degrees, which means even though its all gassed up and working fine, it never really gets that cold.
What I guess I need to know is if the A/C has its own in vent air temp sensor, or does it get it signal from the main Climate Control sensor (that little unit under the dash that pulls air via a little foil hose to the little vent next to the slider controls on the dash)
