Just a query on 20 cam belts. I had a noise from the front and thought a bearing had gone so I removed the various belts from the crank drive and listened but no abating in noise. It sounded like a distributor seizing and got louder with revs. So I pulled off the cam belt cover and listened, still noise. I pulled off the cam belt and examined the belt and "cogs" and the auxilliary shaft, no apparent problems, the belt had been replaced 20K earkier. I thought must be the tensioner bearing so it was replaced to no joy. My mind now says must be the cam seizing so out it comes and, you guessed it, no sign of seizure. The auxilliary shaft was turning fine so what was left the distributor (was the sound coming down the shaft and appearing at the other end?) and the cam belt it self. I changed the belt and noise was gone, so my question is how does the belt make so much noise? Is it the "chords" inside the belt? or "what"?
