Yes it is.is this a rear wheel drive setup ?
It's solid,! Had it made for cruising " inspired by the 203 403 F/W. Never used, but did setup well with clutch and housing on the bench.Curiosity begs the question... what clutch setup is this designed for? And is the back of that flywheel machined out, or is it solid? That would make for a very smooth running setup if it is solid.
What is the original flywheel? Peugeot, Volvo, etc? Would you sell it separately? $$?Bespoke fly wheel plus original fly wheel
Original flywheel for the Volvo 264 was also huge, could be one reason they had such a bad reputation for performance.It's solid,! Had it made for cruising " inspired by the 203 403 F/W. Never used, but did setup well with clutch and housing on the bench.
