As a few of you have no doubt seen, I have been having some fun getting my 407 Coupe 2.7lt hdi back on the road. The most recent issue once i had it back on the road was the car Surging, lack of power, and then stalling. I pulled over, popped the bonnet and...
1. Coolant was everywhere - I tracked this back to one of the expansion tank return hoses, the connecter had cracked and it wasnt holding pressure - coolant had sprayed out of this everywhere
2. Before I did this work, I had some minor surging in traffic - it was one of the things I was hoping would be fixed. This started happening after I replaced the glowplugs - and based on the below I am leaning towards it being an early indicator of head gasket issue
3. I got the car towed home, made a repair to the connector, and flushed the coolant system, bleeding the air out. What i noticed
a. Car starts and idles with no problems.
b. Once the revs get above about 1200 - 1500 rpm - there is a big bubble of air in the expansion tank followed by lots of little bubbles (lemonade) - and she stalls.
c. Got error codes P0104, P0299, P2279.
This is screaming head gasket in my mind - and now I need to decide what to do. I dont know much about these motors, and whether replacing a head gasket is worthwhile - i do know i have already bled some thousands into fixing various issues already - mainly on parts and tools.
So I am looking for some advice. I am thinking
1. Head gasket is likely not leaking much at idle, but is substantially when the turbo kicks in. This is the bubbling in the coolant expansion tank - and the stalling is probably the ECU having a fit over lost boost pressure and or incorrect air fuel mixture. I expect this is also the origin of code P2279 - indicating loss of boost after turbocharger.
2. Tempted to try some of the Nulon head gasket fix stuff. If it is mainly an issue under boost - then my simple mind wonders if it is a fairly small hole/s in the head gasket
3. Possibility of other damage - I don't know how robust these engines are. If I get this fixed, I need to work out whether I pull the heads myself and send them off to a head reco place, pull the engine and get it reconditioned, get a mechanic to do the work, or wreck the car and get another one.
All and any advice is welcome
