Does anyone have a way of establishing the production date based on the chassis number, in this case 504C121786272?
Thanos
Thanos
Hi Thanos, don't know if will help you narrow it down but Scott's is 504C12 1612024 - it is a 1973 ti (LHD EU delivery).Does anyone have a way of establishing the production date based on the chassis number, in this case 504C121786272?
Thanos
Hi Thanos, Yeah Scott grabbed a coupe a few years ago, must have been corrupted by driving yours!! A long term project. It could now be registered in standard form but he's collecting the bits to convert to a V6 later (he has a 3 litre engine, flywheel and BA10/5 already). I'll get him to post some pics. Cheers JimThank you Alex and Jim. I know it is a 74, I just need some official proof of production date for DMV registration. Jim, I didn't know Scott got a coupe, photos please
Yes, but I do find that odd to say the least. This is a service they claim to offer to members....but I've not done it for years so maybe there is now a fee in relation to the service that wasn't paid? Failing that, try Amicale Peugeot 504 and I'm sure they'd help.Thank you, Mike. I did on two occasions, and I am a member but got no reply. Did you write to them in French?
I but a ba10/5 in my 73 cab and had to grind a bit off the inside of the gear box housing to get it to mate up with the torque tubeHi Thanos, Yeah Scott grabbed a coupe a few years ago, must have been corrupted by driving yours!! A long term project. It could now be registered in standard form but he's collecting the bits to convert to a V6 later (he has a 3 litre engine, flywheel and BA10/5 already). I'll get him to post some pics. Cheers Jim
Your supposed to run a ba10 torque tube, otherwise the housing will crack and or leak oil, ba7/5 much nicer box than the ba10, hopefully you don't have a problem.I but a ba10/5 in my 73 cab and had to grind a bit off the inside of the gear box housing to get it to mate up with the torque tube
We have put on some very hard miles without a BA10 torque tube without a problem. Two ways you can do it: We machine the tail of the BA10 gearbox to match the longer lip of the BA7/4 torque tube; or machine the BA7/4 toque tube to match the tail of the BA10/5 gearbox. I will have to disagree with you on the BA7/5, it's a truly shitty box. All three of ours failed in quick order (broken gears) in rally use with 150 bhp engines. Not that the BA10/5 is much better, it just eats synchros instead of gears and the failures are not terminal. The four speeds are fine, both the BA7 and the BA10. But the BA7/5 will not fit Scott's engine anyway as it is a V6.Your supposed to run a ba10 torque tube, otherwise the housing will crack and or leak oil, ba7/5 much nicer box than the ba10, hopefully you don't have a problem.
A BA10 torque tube for a cab is not easy to get in Aus. I dont drive it hard like a rally car ,i just cruse on fine days and it is all OKYour supposed to run a ba10 torque tube, otherwise the housing will crack and or leak oil, ba7/5 much nicer box than the ba10, hopefully you don't have a problem.
