Hi all
With the impending installation of air con into my 504, I had better firstly upgrade my alternator. It is still the original type (I am assuming 35 amps).
I have searched and see that a commodore alternator will fit. Is it for a VN commodore as per this link:
Brand NEW Alternator FOR Holden Commodore VN VP VR V6 | eBay which are 80amps
Now firstly I can see that I will need to swap over the ribbed pulley for the Peugeot v pulley, then how do I wire it up? Is there a direct feed from the battery to the stud on the back of the alternator, then power from an ignition source?
Then I need to remove the original voltage regulator from the firewall and toss out? Do I just tape up the wires that attach to the voltage regulator?
Thanks heaps
Thanks heaps
