I have a 308 T7 which shuts down, often without warning. If I leave it turned off for a few minutes it will generally restart and go again for a few kms before cutting out again. Sometimes there is a display message 'Gearbox faulty' and other times it shows 'Antipollution system faulty'
The scanner shows the following fault codes:
P0336 $07E8 Crankshaft position sensor A circuit range / performance
P0337 $07E8 Crankshaft position sensor A circuit low
P1351 $07E8 IDM Input circuit malfunction/ Ignition coil control circuit High voltage
A mechanic has previously replaced the crankshaft position sensor and the battery has also been replaced, but the same issue persists.
Any suggestions on a possible cause would be appreciated.
