In this case the problem is the windows don't work.
Previous owner had the stereo stolen and the wiring disturbed , after that the windows didn't work.
The window motor works on the driver side as i took the trim off to check
There is power going to the switch on the console but nothing gets to the door.
I tied another switch out of a 206 but the fuse blows so i wonder if there is a short in the wiring and the original switch is burnt out from when the vandals cut the wiring ?
I have had a good look at the wiring but can't see the damaged area, yet.
*My thoughts are to cut the wiring from the switch and put new good wiring in, rather than fiddle with the existing wiring.
Does any body have a very basic wiring diagram for the switch to the window?
The switch seems to change the polarity of the motor depending on the direction it operates in?
The manual i have doesn't tell me what colours come out of the switch.
Switch-five wires, two violet, two grey, earth power. On the 206CC
Is there anything between the switch and the motor?
