pepperpots with 266mm brakes
apitiser
Vancouver Island, Canada
Hi, today I tried to test fit some 266 mm brakes with pepperpots and there is a spot where it rubs. The wheel got bolted on and just rolled around lightly to see if it would fit and once it was taken off I was a bit disappointed.
Does anyone here run 266mm brakes and pepperpots? how did you get them to work?
I also realised that the calipers I picked up were lucas ones so maybe bosch ones will fit or do they rub too?
Also are lucas calipers any good, Bosch ones are better right?
Not all pepperpots are equal, some are slightly different to others and I did try bosch 266 but they rubbed on the wheel weights inside rim. 247 is more than enough for a normal 205. Service the caliper it will repay you for it. Its an Italian versus Spanish I think wheel issue, check the source of yours. Do some reading.
Matthew is right. There are two different types of Pepperpot. You may have to run a 3mm spacer disc for a while, or mill the new pads down the same.
French SMR pepperpots don't fit over 266mm brakes. Italian Speedline Pepperpots do fit over 266mm brakes.
You only need to shave a mil or so off the caliper with a flap wheel etc.
Could be a combination of aftermarket pads and corrosion on the discs. Doesn't look like its hitting by much.
Surely it's the fixed caliper yoke that is touching isn't it - the actual floating caliper part doesn't protrude as far.
Amazing co-incidence that I have just faced the same issue with my 406 - I bought a set of 307 16" rims from a wreckers, believing that their offset was greater, but found that they sit closer in to the hub and brakes, and rubbed against the front yokes. After thinking about it, I went with your suggestion and used the angle grinder to take a couple of mm off the yoke. They're overengineered and can be safely lightened, right?
Alec
