Hi folks,
I'm bashing my head against the wall on a s1 205gti.
She has no spark and as such won't start, I have correct readings at the coil, both primary and secondary and have tried a ignition module.
Things to note, I'm not getting any movement on the tacho when cranking, fuel pump has no power even after some time of cranking but the tachymetric relay seems OK.
I'm down to thinking ecu fault, or dissy internal but not around the system well enough to think through It properly...
This car had undergone a engine removal and half a reinstalation, I pulled it all back out to try and tidy and assign everything, I'm relatively confident that everything needed is plugged in, and have cleaned terminals/earth points...
Thanks folks
Thanks folks
