I am going to break an unwritten rule of this forum and ask for assistance diagnosing a clutch problem in my girlfriends Diahastsu Charade (1985) eek! eek!
The clutch pedal has gone soft and when it is engaged it will not go into gear. If you push hard to get it into gear the engine starts to labor slightly and you can hear a grind...my que to stop pushing.
The cable is fine, it was replaced only 6 months ago and it moves the lever it is connected to going into the top of the gearbox. However, this lever is very soft to move. I would assume that as a clutch lever it would be stiff. I can move it with one finger.
The clutch was not slipping before this happened, and it occured very suddenly.
So what could be in the clutch assembly that could of broken?
<small>[ 02 June 2002, 09:59 AM: Message edited by: Phasis ]</small>
