Thats good to hear as there were lots of complaints ages ago about the auto mode around town. Pity we didnt get the MOS version here though. Ateco has no plans to bring it here either....
chris said:Rear brakes on a GS are notorious squeakers, but you can quite easily fix them so they never do it again, ever. Just pull the pads out and smear the backs and edges (not the faces!) with antiseize goo. Might be worth a try... I do it to any new brake pads I fit now.
chris said:Hi Andrew,
Walk straight past the anti-squeal products, as far as I can tell they're a gimmick.
You want anti-seize paste of the type you'd put on a bolt, somewhere like Repco shold have it but might offer you Loctite instead, which is not what you want . The stuff I've got is called Molycote (I think), Copaslip is another one. Smear it fairly thickly on the back of the pad where the cylinder presses, then put a thin smear along the edges of the pad where they touch the caliper. DON'T get it on the front of the pad or on the disk!
With a GS the rear calipers often sieze as they don't get much exercise, so while you're in there lever them back a bit with a screwdriver to make sure they move OK. Press the brake pedal and repeat as needed. The anti-seize should keep them free after that.
Hope that helps,
artisan said:It will go straight to the top of my "things to do" list
Is this a Citroen dealer only? Be interested what the breakdown of the C2 20K service is see how it compares to Peugeots offerenings on small cars. Suspect it's probably very very similar .. then again a Corolla is probably the same too !Nil Time said:It will be interesting to hear how you go with the brake fix, gibgib...I am booking in my C2 for its 20K service in about a month, so if it is successful, I will be asking that they fix mine as well. Cheers
XTC206 said:Is this a Citroen dealer only? Be interested what the breakdown of the C2 20K service is see how it compares to Peugeots offerenings on small cars. Suspect it's probably very very similar .. then again a Corolla is probably the same too !
- xTc -
gibgib said:20,000k service (done yesterday also) was $262 including Mobil 1 oil.
Pays to shop around for Victorians bigtime it seems.....Wow, good price....I called the other Citroen Service place in Melbourne - and was advised that it would be about $500.00
danielsydney said:Pays to shop around for Victorians bigtime it seems.....
jasC2 said:the noise in the citroen c2 rear brakes is a recall issue..
take your c2 to your dealer an they will fix under warrenty..
danielsydney said:The rear brakes on my C3 have sqeaked since new....
