Hi! Just picked up a Pug 206cc, 2.0l 5 speed. 2004 flavour.
Gradually getting her ready for RWC.
However, the horn doesn't work!
The horn itself is functional. I've tested it off the car. When I press the horn button, I can hear a relay click under the hood.
The fuse is good.
But, I can't find the relay! Is it actually hard wired under the fuse panel?
I wanted to test the relay itself to check that it is functioning.
Or, tap into the wiring direct from the fuse panel to check the horn function there.
Save actually removing the grill from the car and tracing the wiring, I'm not sure where to head next.
I'm hoping someone has already experienced and troubleshoot this problem before.
Cheers and thanks!
The fuse is good.
Cheers and thanks!
