I have a couple of 395-13 type gearboxes from R17 Gordini and R18, one of which is going in to my ’75 R12.
They both have three electrical senders on them. I don’t know what they’re for.
I wasn’t going to worry about them, apart from the reversing light switch, but it’s getting to me.
I don’t cope well with unanswered mysteries.
So I’m seeking help from the brains trust.
One sender is on the side, has two connectors and the trusty multimeter in conjunction with manipulation of selector suggest it’s the reverse light switch.
The second is on the top near the rear, but not on the end casing over the fifth gear. Single electrical connection (presumably opens/closes to earth on activation) and doesn’t appear to connect with anything inside. Sender is barely longer than its threads with nothing protruding into the gearbox casing. I’d have thought an oil temp sensor would be down low actually in the oil. Air temp or pressure is just nonsense, surely...
The third is on the end of the casing at the selector end covering the fifth gear. It’s near where the speedo cable attaches. Looks to be in proximity to the end of the secondary shaft. Two electrical connections. I’m thinking something to do with road speed related rotation - some sort of signal to engine electronics which both the donor vehicles would have had. Might also be primary shaft rotation to detect engagement of clutch?...
I figure someone would know the truth of these three amigos, but I‘m willing to entertain plausible offerings.
I need to get some sleep....
thanks, Geoff
thanks, Geoff
