Light switching
T03Y
Active member
Byron Shire
Hi all. Purchased a cheap high km 2006 307 wagon. Diesel 6 speed auto. Goes well. Has a few issues for blueslip in NSW.
light switching is odd. Apparently I have no park/tail lights, and they’re suggesting replacing the switch stalk. Are the parks a seperate globe? Is the stalk a tricky job?
Further to this- I get an ‘ambient light sensor faulty’ warning on the display. Should I start with that re the lights?
Ahh - we had a 2 litre 2006 307, and it had 'dark sensing' headlights. AFAIK, the 'ambient light sensor', like the rain sensor, was in the windscreen. A cheap replacement windscreen would not have these sensors, but that shouldn't stop anything working - you would just have to manually switch the headlights on (& your windscreen wipers).
Non-working tail lights would be a fuse on most cars... Does this car have a towbar? Even if not, it could have been removed & sold separately. It could be worth checking whether the wiring has been butchered by fitting of towbar wiring.
As to the light control stalk - earlier 307s had problems with the COM2000 unit (housed in that stalk) and switch failures (commonly affecting blinkers), but a 2006 model car should have the later unit, which is generally trouble free.
I would recommend getting a code scanning tool - there may be useful information stored. You don't ever travel up to the tablelands do you? I am in Tenterfield from time to time, but rarely venture down your way.
Alec
Thanks great reply. Actually the wipers are odd too- if I bump it down onto auto momentarily, they seem to stay on. Rotating clockwise sprays the front but wipes the back-?! So perhaps it points to the windscreen as you say.
Yes it has a towbar, the flat Peugeot type.
I was in the rear left replacing a globe and found a unit with one little fuse which did need replacing. I have come across some suspicious wiring repairs 🙄. Do I need to change ‘modes’ and disable the auto stuff somewhere?
No I don’t get out of the byron shire much but can prob get a scan in Lismore.
Thanks again.
Just to resolve my own post – turned out the park globes were both blown, a $4 fix. Also, the lights were set to come on automatically (and I've gathered that the sensor was originally in the windscreen, probably no longer), so by turning off that function I have lights that now perform normally. It's got rid of the 'ambient light sensor' warning that would appear on starting too.
This was a happy outcome compared to replacing the switch stalk as suggested by the local blue slip guys, or the $1800 computer as suggested by the Peugeot specialists. Phew!
And not one checked the globes wow
4008
Gone but not forgotten C5 x7 3008 206 GTI 180 306 XR SED 405 MI16 x2 xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
Fix it right the first time
