The offical figures are:
8.35:1 compression 504 injected engine:
104hp DIN
168Nm DIN
8.8:1 compression 504 injected engine (with big bore exhaust manifold?):
106hp DIN
A carby motor with a weber, big more manifold, 9-9.5:1 compression, square port head and a Wade 112 cam would be capable of similar or slightly higher power and similar or slightly lower torque to the injected engine, but possibly slightly higher up in the rev range. Something in the range of 105hp and 165Nm would be what to expect. The carby 504 has a slightly lower diff ratio than the TI, so with a similar output, it will accelerate faster.
If you can get an XN1A carby head with four branch inlet manifold from NZ or somewhere, those engines have 108hp standard.
Dave
